Re: Re: wet vs. dry sleeves
Posted by tubba_JD420C_ny on September 08, 2002 at 18:10:56 from (24.59.61.54):
In Reply to: Re: wet vs. dry sleeves posted by Diesel Don on September 08, 2002 at 07:42:29:
I have seen this done during an in-frame that was being done on a Dry-sleeve Perkins 6-354 in a White 2-85 that has had too much ether put to it, which bent the rods, etc. )moral-go easy on the starting fluid, that overhaul cost the poor guy about $4,500) But a few passes along the inside of the sleeves with a small diameter welding rod shrank them enough to get them out easily.
Post A Followup
: Re: Re: Re: wet vs. dry sleeves
