Re: Can a tractor with a mag start on its own?!
Posted by andy on September 08, 2002 at 21:17:19 from (216.51.128.249):
In Reply to: Can a tractor with a mag start on its own?! posted by John (SC) on September 06, 2002 at 18:43:09:
A farmer friend of mine was woke from a nap by his IH 560 running in circles in his front yard. Luckly, the tractor never hit anything or caused injury. Accordingly the wiring had shorted out in the starting system.
Another friend has a IH 504. Sometimes the thing would not shut off with the key after it had been ran. On occausion it would power up the ignition by itself and run the battery down. Once it blew the ignition coil into bits. The coil heated up and the oil expanded. Happened to be nearby .... sounded like a bomb ..... no coil! Interesting discussion.
Post A Followup
: Re: Re: Can a tractor with a mag start on its own?!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
