Re: Re: Re: Whoops!! Poetically known as oh S$% !!!!
Posted by Hugh MacKay on September 09, 2002 at 14:58:43 from (64.228.11.61):
In Reply to: Re: Re: Whoops!! Poetically known as oh S$% !!!! posted by joe on September 09, 2002 at 04:48:32:
The SA doesn't have the 3 bolts Joe, I think you have to remove pin through shift lever. It is a long long time since I've done this but I think you have to remove pin that retains coil spring around shift lever. This is what stopped me this am, it is 40 years since I've done this. The fact is you have to remove that shift lever and follow Joe's instruction. Lower end of shift lever is worn and needs to be built up so it snugly fills the notch in shift rails, one at a time. I have a nagging feeling there is something yet to be found out here. I wish he had told us whether he can get to 2nd, 3rd and 4th, and left wheel only turning in reverse causes a question. Is it off ground? or does right wheel have better traction? Give us more precice detals.
Post A Followup
: Re: Re: Re: Re: Whoops!! Poetically known as oh S$% !!!!
