Re: 130 gears grind when shifting
Posted by Rick(MN) on September 09, 2002 at 18:58:09 from (64.12.97.13):
In Reply to: 130 gears grind when shifting posted by CD on September 07, 2002 at 09:18:48:
Another thing that I have ran into that I didnt see posted is somtimes, the dust from the clucht lining will collect around the inside of the flywheel and just catch enough on the disc to keep it from stopping by itself. Between lubrication and a good cleaning in there, my guess is you will clear up the problem without any expense. (assuming you clutch isnt worn out) Rick
Post A Followup
: Re: Re: 130 gears grind when shifting
