Re: bale hay and my farmall ( need advice)
Posted by FC on September 11, 2002 at 12:48:26 from (208.14.16.15):
In Reply to: bale hay and my farmall ( need advice) posted by Kelly C on September 10, 2002 at 21:48:25:
The H will handle a square baler with no problem, however the live PTO sure makes it nice. Easy to get spoiled to those type things. I have baled many bales with a McCormick #45 pto baler on a C baling approx 70 acres/yr, and you just get used to making smaller windrows and taking it slow. I also got real good at clutching and pulling into neutral in a heavy spot. I'd say if you do not have that many acres to do it would not justify buying an additional tractor just to bale.
Post A Followup
: Re: Re: bale hay and my farmall ( need advice)
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
