Re: I DID IT!! ( removed the liftall pump)
Posted by williamf on September 12, 2002 at 05:38:58 from (66.82.9.14):
In Reply to: I DID IT!! ( removed the liftall pump) posted by Kelly C on September 11, 2002 at 19:15:55:
Neatly done. You'll find that that arrangement will raise it almost as easily. Being able to make small adjustments without having to worry about balancing it makes it a piece-a-cake.
Post A Followup
: Re: Re: I DID IT!! ( removed the liftall pump)
