Re: I DID IT!! ( removed the liftall pump)
Posted by FC on September 12, 2002 at 06:47:06 from (208.14.16.15):
In Reply to: I DID IT!! ( removed the liftall pump) posted by Kelly C on September 11, 2002 at 19:15:55:
Funny how when necessity arises one can find a way. I once needed a method to remove an engine/transmission from a car, and had no hoist, or tree limb stout enough near. After a little thought I drilled holes through the 6x6 supports in the door of my pole barn, some all-thread through the holes, and attached a length of chain across the door. A come-a-long on the chain and I was in business. Only drawback was that it was in the door, but worked great.
Post A Followup
: Re: Re: I DID IT!! ( removed the liftall pump)
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
