Re: Farmall A Loose Sterring
Posted by Roger on September 12, 2002 at 16:35:26 from (198.31.223.131):
In Reply to: Farmall A Loose Sterring posted by plh on September 12, 2002 at 13:33:08:
I have a Farmall A that had a real loose steering system. It turns out most of the play was in the connection between the pivot arm and the shaft that comes out of the bottom of the steering box. I tightened the bolt on it and it now has much less play. In most cases, though it is usually the gears being worn out. Roger
Post A Followup
: Re: Re: Farmall A Loose Sterring
