H Rocker arms
Posted by 230,H,M on September 13, 2002 at 05:10:50 from (209.246.214.177):
The rocker arms on my H are cast material. the surface that rides on the valve is not square to the valve . This surface is taperd (from front toward rear of engine). I have never seen a rocker arm before that was not square to the valve stem. I have a rocker shaft with pressed welded steel arms. These arms have inserts on the valve end. The insert looks like the head of a nail where it rides on the valve. The inserts are apparently permanent to the arms. This assembly is for an H as I understand it. Have any of you run into this before? Is this assembly just a later version and still useable in place of my original with cast arms?
Post A Followup
: Re: H Rocker arms
