Re: Broken Head bolts on my Lo boy???
Posted by Michael Soldan on September 14, 2002 at 16:40:49 from (216.46.130.12):
In Reply to: Broken Head bolts on my Lo boy??? posted by Ron in NJ on September 13, 2002 at 17:39:59:
Ron you have a tough row to hoe but it can be done. Getting broken studs out requires a good sharp center punch a set of sharp drills and a good set of easy outs. I prefer the square shank easy outs as I believe the bite in better than the spiral ones. Getting the punch in exact dead center is important and drilling , starting with a small drill and increasing the size up to the size of your easy out. Tap the easy out in with a sharp blow and start turning...don't be afraid to use some heat around the area of the broken stud...hopefully you will feel it break free and begin to turn...soak with penetrating oil before you begin the task...the night before..don't be afraid to drill larger and larger holes to get the bigger easy outs in...you can tap out the hole after even if it is burred and restore the thread. You need lots of patience, don't hurry..each bolt out is a moral victory..good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
