Re: ground speed
Posted by Hugh MacKay on September 15, 2002 at 09:16:28 from (64.228.11.25):
In Reply to: ground speed posted by JEFF FISHER on September 15, 2002 at 08:50:14:
There should be a table of ground speeds both direct and TA in your manuel. Having said that, your tach or ground speed table are not accurate enough for spraying. Only system truly accurate is to time tractor with watch for 30 or 60 seconds and measure distance travelled.
Post A Followup
: Re: Re: ground speed
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
