230 implements
Posted by TerryC on September 15, 2002 at 11:26:13 from (208.16.108.130):
Its sunday afternoon, so i thought I would fire off some general questions. The 230 is the first tractor I have had, also the first I have rebuilt an engine on. I got it along with a 2b plow, sicklebar, bushhog, blade, boom, disk, and front and rear cultivators. I am new around tractors in general, so am learning a lot regards to stuff yall probably do in your sleep. These are all fast hitch implements, so the initial hookup is obvious. I am wondering how to hook up all the other bars and chains and such for the sicklebar. When I got it, we had to go into the woods to find it, so the seller was no help in how to hook it up, since he never used it. I also found that it seems i will have to pull the rear tires out in order for the rear cultivator to fit; however, if i do that, i cannot load it on the trailer.... Anyhow, none of this is real pressing, just a rainy sunday so I wanted to pick yalls brains a bit. ALso, is there a box blade that this tractor can pull with the fast hitch hookup? and what about post hole digger.... there is also a question of what all the adjustment things on the rear of this thing are for. I have figured out he screw for side to side tilt of the hitch, but that is about it. A long post, so answer what you can or are willing to, as I appreciate reading the advice on here. Thanx for your time.
TerryC
Post A Followup
: Re: 230 implements
