Re: Re: Re: Farmall H with flames out the exhaust
Posted by Steve - IN on September 16, 2002 at 08:15:55 from (12.222.132.139):
In Reply to: Re: Re: Farmall H with flames out the exhaust posted by Neill D on September 16, 2002 at 05:34:20:
Neill,
From what you describe heat is the cause. An exhaust valve or valves is sticking open, and letting the combustion flame out into the exhaust. When the valve and valve guide expands with heat, it's getting stuck. If it were timing, you'd expect the flames to show up much sooner than after an hour or so of running.
If you don't want to restort to wrenches, that leaves only liquid fixes. Might try Marvel Mystery Oil -- or any top end lube you find at WalMart, Pep Boys, etc. Also, get a cooling system flush and refill to make sure water is circulating well through in the water jacket around the head. Even cleaning out the junk in the radiator itself with a hose might help -- anything to make it run cooler.
If it's been doing this for a while, you're probably going to have some burned exhaust valves -- so eventually someone is going to need to let the tractor feel the touch of a wrench.
Good luck with it.
Steve
Post A Followup
: Re: Re: Re: Re: Farmall H with flames out the exhaust
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
