Re: trans oil
Posted by Honkey on September 16, 2002 at 17:02:21 from (64.68.163.10):
In Reply to: trans oil posted by Scott(TN) on September 16, 2002 at 12:35:44:
Scott,
You cannot use 80/90 in your transmission. They require Hytran. The needle bearings in the TA and IPTO need the thinner oil.
You can get it in the bulk for around $5.00 a gallon. If you have an empty bucket or two lying around, just take them to your CIH dealer or anyplace that sells oil in the bulk and get them filled.
Matthew in SD
Post A Followup
: Re: Re: trans oil
