Re: farmall h smoking after rebuild?
Posted by gm on September 16, 2002 at 17:30:01 from (207.87.72.91):
In Reply to: farmall h smoking after rebuild? posted by Bob on September 16, 2002 at 14:59:53:
I just rebuilt an ATV and have the same
problem. Except it doesnt go away when
under load. I am thinking its
the head gasket since I didnt replace it.
Either that or the valve guides.
I havent read up much on the rings seating bit,
but seems like it shouldnt smoke that much
due to that. Also, I would think under load
you would get more smoke, if the rings were
leakin the oil.
-Greg
Post A Followup
: Re: Re: farmall h smoking after rebuild?
