Re: farmall h smoking after rebuild?
Posted by Phlogiston on September 16, 2002 at 17:33:36 from (65.129.89.147):
In Reply to: farmall h smoking after rebuild? posted by Bob on September 16, 2002 at 14:59:53:
Did you alternate ring gap ends? If they are all lined up on top of each other you will get constant blue smoke. Each end gap should be 180 degrees from the next one.
Post A Followup
: Re: Re: farmall h smoking after rebuild?
