Re: h keeps dying
Posted by Ray on September 16, 2002 at 18:57:31 from (205.138.22.217):
In Reply to: h keeps dying posted by Jay Carter on September 16, 2002 at 18:12:47:
You probably have rust or dirt glob floating around and plugging the inlet in the gas tank. When your tractor's motor dies the next time, Quickly disconnect your fuel line at the carb. to see if your getting gas. If you are getting gas this far,(then it could be a sticking float or plugged carb.). Before you tear the carb. apart though, Try testing a spark plug wire for spark by cranking the engine right after it dies to see if you can get a spark to jump to the motor block.
Ray
Post A Followup
: Re: Re: h keeps dying
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
