Re: farmall h smoking after rebuild?
Posted by frankSCPA on September 17, 2002 at 09:59:25 from (209.240.198.63):
In Reply to: farmall h smoking after rebuild? posted by Bob on September 16, 2002 at 14:59:53:
i gauruntee you oil is getting through the valve guides. get some automotive-type seals that will slip over the OD of your guides and still be small enough the spring wont pull it off. your H valve stems are .341"- the same as small-block chevrolets.hope this helps-it worked for us.
Post A Followup
: Re: Re: farmall h smoking after rebuild?
