Re: '49 Farmall M died
Posted by Mike ISW on September 17, 2002 at 15:56:48 from (64.12.97.13):
In Reply to: '49 Farmall M died posted by Gary on September 17, 2002 at 08:02:44:
You need to first investigate two different systems and isolate the problem. Ignition or fuel(gas). Fuel in tank? Fuel getting to carb? Fuel getting to cylinders? Spark at plugs? In my opinion Champion plugs should be taken off the market, but use what you like. When you get back to it. Crank her over for a bit. Pull a plug. Is it wet and smell of gas? Check ignition side. If no gas check where your flowed may be interupted. Ignition checks are a bit more complicated but your in the right direction. Good Luck
Post A Followup
: Re: Re: '49 Farmall M died
