Re: '49 Farmall M died
Posted by Short cut diagnosis/Michael Soldan on September 17, 2002 at 17:14:50 from (216.46.130.28):
In Reply to: '49 Farmall M died posted by Gary on September 17, 2002 at 08:02:44:
Gary, everyone has given some good idea about what is wrong..here is the quickest diagnosis..seconds and you will know..Take a mister bottle and fill it with gas, pull the air cleaner tube off the carb..kick her over and spray the misted fuel directly into the carb...if it starts to run its a fuel problem if nothing happens go to the electric diagnosis..you will eliminate one system very quickly. As you describe what happened it sounds like fuel..good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: '49 Farmall M died
