Re: Farmall H Hood
Posted by Night Stalker on September 17, 2002 at 21:50:29 from (207.239.97.193):
In Reply to: Farmall H Hood posted by Matt on September 17, 2002 at 19:46:44:
You can weld the cracks with a wire welder, then grind and sand to a finish. As for any dents or dings sand the metal down until it is clean or bare and then you could use JB Weld to fill. Glazing putty is not intended to be used to fill large dents etc. It is very good to fill pitting and very small scratches etc. The glazing putty will not hold up in an area where there is a chance of movement, as you have discovered.
A good source for a used hood is "Steelwheel Ranch", they do have a web site also.
There is a hood listed on the YT auctions.
The ad states that it is for a SUPER H, I don't know if it will work on a regular H.
Some of the others here will know the answer to that.
Good Luck
NS
Post A Followup
: Re: Re: Farmall H Hood
