Re: Time to rebuild the upper Bolster on H
Posted by Bob M on September 18, 2002 at 04:46:50 from (165.170.128.68):
In Reply to: Time to rebuild the upper Bolster on H posted by Kelly C on September 17, 2002 at 20:39:09:
Kelly - I rebuilt the upper bolster on my Super H a couple years ago. Problem turned out to be a missing part (a spacer) beneath the large thrust bearing. After replacing the missing spacer and installing new bushings, the tractor now steers fine.
Most difficult task was getting the sector gear loose from it's tapered spline the pivot shaft. Required some serious pounding on the top of the shaft with a sledge (with a piece of brass flat to protect the threads).
Punch below for a few pix of the job....
Post A Followup
: Re: Re: Time to rebuild the upper Bolster on H
