Re: HELP!!! Putting the duals on the Super M for the show!!
Posted by Hugh MacKay on September 18, 2002 at 18:45:44 from (64.228.11.185):
In Reply to: HELP!!! Putting the duals on the Super M for the show!! posted by Tim Malin on September 18, 2002 at 17:57:03:
Tim: You are using two sets of SM wheels with 11 or 12 inch rims I presume. I did the same on 560 using 560 cast wheels and a set of SM cast wheels, should be the same except I was using two different size tires and rims; 15.5 and 13.6.
The inside wheel must be dish in and the outside wheel must be dish out You now have four mounting rings on two rims and two mounting positions on each ring on rim, either side of cast wheel. My tires were about 2 inches apart. Outside wheel was flush with end of axle. Tractor also had flat top fenders from 656. I put them on 560 when I installed cab on 656. Inside tire was about an inch from fender.
Hope this helps, if you want more just ask. I enjoyed the letter, with that kind of hospitality you know your not that far away. Hugh.
Post A Followup
: Re: Re: HELP!!! Putting the duals on the Super M for the show!!
