Re: broke ring/s?
Posted by Jim on September 18, 2002 at 19:00:03 from (64.12.97.13):
In Reply to: broke ring/s? posted by KX on September 17, 2002 at 13:12:00:
You could alos have a bad injector or cracked the precup. With eht engine running try cracking loose the injector lines a the injector one at a time to wee if it is just one cylinder and check that injector to see if the fuel is atomizing or just spraying in a stream.
Post A Followup
: Re: Re: broke ring/s?
