Re: Help! New Rebuild is too tight!!
Posted by mr. right on September 18, 2002 at 19:37:40 from (66.24.112.126):
In Reply to: Help! New Rebuild is too tight!! posted by Jason on September 17, 2002 at 13:03:47:
jason
have all tools calibrated
check crank specs
check parts
check torque specs
plasti-guage the lower end and if it checks out all right then keep going.
you are doing everything perfect.
If you can turn it by hand its not tight enough.
Post A Followup
: Re: Re: Help! New Rebuild is too tight!!
