Re: M farmall gear shifter, need replaced?
Posted by BEL@IN on September 20, 2002 at 11:06:01 from (209.84.168.154):
In Reply to: M farmall gear shifter, need replaced? posted by Aaron on September 20, 2002 at 10:01:22:
You probably have a very worn finger that extends into the trans.. I just redone mine. First release the spring on the shift lever that holds the cap down. Each end of the pin that holds the shift lever is covered with a small freeze plug cover, about 5/8 inch, knock it out with a sharp punch and that will expose the real pin. It can usually be pulled out with a magnet as it is probable loose from wear. It is 7/16 inch and propably worn. Make a new one from a grade 5 bolt. You can now lift the shift lever out and see it is probably very worn and can be built up with weld. It takes som patience to get a good fit,weld oversize and carefully grind and file for the proper fit. Good luck
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
