Re: How to remove piston rod seal retainer on fast hitch cylinder?
Posted by Lloyd on September 20, 2002 at 18:06:56 from (207.177.71.237):
In Reply to: How to remove piston rod seal retainer on fast hitch cylinder? posted by Kilian on September 20, 2002 at 08:57:05:
I don't know for sure what you have, but I have seen retaining rings that have to be spun out through a slot in the side of the cylinder. You may have one of those. Hope this helps.
Post A Followup
: Re: Re: How to remove piston rod seal retainer on fast hitch cylinder?
