Re: transmission on H
Posted by Mike ISW on September 20, 2002 at 18:31:55 from (152.163.189.203):
In Reply to: transmission on H posted by Bryce Andreasen on September 20, 2002 at 09:10:05:
Make sure the 2 bearings in the driveshaft that goes thru the front of trans housing are good. There s/b no play in this shaft. Mine were shot. Also check 4th/5th sliding gear for wear. Rails and/or detents could be a problem. Shift lever pivot may be another place to look or the end of shaft could be worn. Let us know what you find. Good Luck. 3 splits in one year on same tractor sounds like a pain in the a**!
Post A Followup
: Re: Re: transmission on H
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
