Re: need to install a TA
Posted by tom on September 21, 2002 at 15:23:40 from (152.163.189.203):
In Reply to: need to install a TA posted by ugly jim on September 21, 2002 at 14:48:28:
It is quite a job if you have never done it yourself. You should at least watch someone else do it a few times. There are so many little tricks to learn and there always seems to be other worn parts that you need to watch for. I sure wouldn't take it on yourself with out some knowledgable help. It will cost at least a $1000, maybe more. You first split the tractor between the TA housing and rear end. After you roll it out, you seperate the TA housing from the clutch housing and lay it on your bench and go to work. Safety is a big concern. You really need to brace the rear end well and your engine stand needs to be strong enough to support engine and TA, or you can use a TA stand with the engine stand, the better option. Good luck! You have a lot of work ahead of you.
Post A Followup
: Re: Re: need to install a TA
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
