Re: SMTA Steering
Posted by Andy Martin on September 22, 2002 at 07:17:35 from (12.74.160.19):
In Reply to: SMTA Steering posted by Farmer on September 21, 2002 at 19:14:44:
My experience has been that it is usually the lower bolster bearing. Jack up the front of the tractor and try to push the front wheels sideways. If there is lateral movement in the entire assembly then the large sleeve bearing right behind the grease zerk near the crank stub on the front of the tractor is loose. It will make the tractor wheels wobble and is the culprit. I've never had a bad worm gear or little ball bearing out of 11 M's and 4 H's. Of course anything can go bad so determine what it is before fixing it and you will save time and money. The big cast inverted Y that the vertical steering shaft goes through is called the "bolster". It connects the two frame rails together. So there is an upper bolster bearing and a lower bolster bearing each with seals. Modern grease works well in steering gearboxes so if you have bad seals and aren't restoring to total perfection put grease in the gearbox.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
