Farmall Tractors Discussion Board
Re: fluid in the fan cover
Posted by big fred on August 22, 1999 at 10:18:23 from (199.238.169.69):
In Reply to: fluid in the fan cover posted by tim lucas on August 22, 1999 at 08:17:42:
It takes the same oil as the crankcase, fill it 1/4 full. If you overfill, just leave the filler screw out and turn the fan slowly and let the excess run out. You will need a 13/16 wrench to remove the fan, and there is a 1 inch nut behind the fan bracket, that sits in a slot in the fan bracket casting. When it gets loose, you will need a 1 inch wrench for it if it doesn't just spin off with your fingers.
Post a Followup
: Re: Re: fluid in the fan cover
