Re: Starter problem-need cheap advice
Posted by Michael Soldan on September 23, 2002 at 17:14:01 from (216.46.130.29):
In Reply to: Starter problem-need cheap advice posted by AGR538 on September 23, 2002 at 14:49:52:
AGR538, the starter can be rejuvinated. New brushes are likely needed and the armature can be freshened up with some fine emery cloth, just to shine it up. The brushes aren't that hard to change. Check end play as well, if the armature will not turn freely you need to replace the end bushings as well. Bench test the starter and check end play first...if it won't turn over on th bench you may need a rewind in which case a used starter is an option. Definitely check your cables and ground as F14 has suggested...Good luck from Mike in Exeter Ontario.
Post A Followup
: Re: Re: Starter problem-need cheap advice
