Re: W-30 Flyweel Removal
Posted by JerePa on September 23, 2002 at 19:14:32 from (66.109.255.238):
In Reply to: W-30 Flyweel Removal posted by F-Dean on September 23, 2002 at 17:51:47:
If the pin isn't drilled & tapped, you may have to drill & tap it. Then use a silde hammer to pull it out. Some of those tractors used a guide pin when installing the flywheel. Those pins should have been tapped. Don't know for sure if the tapered pins were tapped.
Post A Followup
: Re: Re: W-30 Flyweel Removal
