Re: Re: Re: Starter problem-need cheap advice
Posted by Tom Olson on September 23, 2002 at 20:17:40 from (24.164.230.127):
In Reply to: Re: Re: Starter problem-need cheap advice posted by Ron Hart on September 23, 2002 at 19:59:30:
Had same problem with my Super A earlier this year. I have seen starters on the larger "red iron" that looked the same as mine with the start switch mounted on top of the starter. Disconnect the battery cables and take the start switch off the starter and look at the contacts. Look at the contacts in the switch itself and the one on the body of the starter. Mine were badly pitted and had been heated because of the resistance (you can tell when a contact has gotten hot). I also had to resolder the field coil wires in that contact that sticks up through the starter housing as the heat had cause the joint to go bad.
After replacing the switch and cleaning up the other contact, the starter worked like new.
Post A Followup
: Re: Re: Re: Re: Starter problem-need cheap advice
