Re: ? Cub plow parts
Posted by Tom W on September 24, 2002 at 17:12:38 from (67.208.85.216):
In Reply to: ? Cub plow parts posted by Alvin NE WI on September 24, 2002 at 12:34:02:
Alvin, the draw bar on the cub has to be turned around backwards and one bolt has to be taken out of each side of the draw bar, so when the draw bar is attached to the front holes, it can move up and down. The plow bolts to the draw bar , off center to the right. The chain on the [plow attaches to the lift arm on the rear of the tractor. You also new a draft control lever that attached to the draw bar. The right hand wheel has to be turned in close to the fender. I don't have mine on the tractor yet or I would send you pictures
Post A Followup
: Re: Re: ? Cub plow parts
