Re: farmall 140 front hydraulic leakdown
Posted by joe on September 24, 2002 at 18:50:57 from (66.43.207.226):
In Reply to: farmall 140 front hydraulic leakdown posted by Dennis Koestler on September 24, 2002 at 18:35:06:
It is either a bad seal in either of the hydraulic cylinders, or a bad seal in the valve. To test, cap the lines on the each of the hydraulic cylinders (i assume there are two, but I'm not familiar with the tractor and cultivator). If one of the cylinders seeps down overnight, it is that cylinder that needs a new seal(s). If no cylinders leak down, then it is your hydraulic valve that needs help, and they are not all that hard to rebuild, nor are the cylinders.
Post A Followup
: Re: Re: farmall 140 front hydraulic leakdown
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
