Re: 560D Injection pump issue?
Posted by Honkey on September 26, 2002 at 10:46:20 from (64.68.163.16):
In Reply to: 560D Injection pump issue? posted by George on September 24, 2002 at 19:27:55:
George,
If all else fails and it still doesn't have fuel at the injectors, you might have a stuck metering valve. You can move it with the pump still on the tractor. But it requires removing the top cover of the pump. I would leave it to a professional if you have never been into a pump before. Cleanliness is an aboslute must.
These parts have very small tolerances. The heat from your hand will make it expand to a point to where it will not fit in the cam ring. Two years of setting combined with a little water in your fuel and they will stick. You can try moving it, but it will probably stick on you again.
Good luck
Post A Followup
: Re: Re: 560D Injection pump issue?
