Re: MF Grain Drill
Posted by KX on September 26, 2002 at 12:36:34 from (66.129.8.2):
In Reply to: MF Grain Drill posted by Dale Kite on September 25, 2002 at 15:59:28:
I have a JD BF-D grain drill and some of my tubes were bad, JD said that they do not make them anymore. I had to use the universal rubber sleeves. They work OK but I like the originals for the way they coil up into the drop when disks are raised. The rubber ones just fold up where they can dry rot at the folds. I guess this is just more of the "planned obsolescense" we are all slave to. Nothing is built to last anymore.
Post A Followup
: Re: Re: MF Grain Drill
