Re: Gear Lube in Final Drive, and a rage
Posted by Glenn(WV) on September 26, 2002 at 20:12:45 from (67.201.149.208):
In Reply to: Gear Lube in Final Drive, and a rage posted by Steve on September 26, 2002 at 16:26:43:
You could use either one. Hy-tran will absorb water better than 90-weight. If you haven't replaced the seals and you put Hy-tran in it, the seals may leak because it's thinner than 90-weight(roughly about 10-weight or so).
Post A Followup
: Re: Re: Gear Lube in Final Drive, and a rage
