Re: 51 M Has Puny-Weak Spark
Posted by Doug in OR on September 27, 2002 at 08:55:12 from (12.225.51.197):
In Reply to: 51 M Has Puny-Weak Spark posted by TX Joe on September 27, 2002 at 08:00:31:
Do you have a good, solid voltage at the coil? A poor connection at any end of the wire feeding the coil could cause a significant voltage drop.
Also, check the spark right from the coil. If it is nice and blue, your distributor cap could be defective or dirty.
Post A Followup
: Re: Re: 51 M Has Puny-Weak Spark
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
