560 Valve Lash Adjustment Sequence
Posted by Walt on September 27, 2002 at 15:44:42 from (68.64.206.50):
I'm rebuilding my gas 560 (new pistons, rings and sleeves plus renewed rod and crank bearings and reworked head). I'm at the point where its time to put on the head and set the valve lash. The firing sequence is 1-5-3-6-2-4 and I assume the valve adjustment sequence would follow the firing sequence with both valves for each cylinder being adjusted when the piston is at TDC on the compression stroke (at which point both valves are closed). Is this correct or is there some other order?
Post A Followup
: Re: 560 Valve Lash Adjustment Sequence
