Re: Gas tank solution
Posted by gene b on September 29, 2002 at 00:22:37 from (67.251.189.93):
In Reply to: Gas tank solution posted by Wanna B on September 28, 2002 at 09:08:43:
the way to check your system is to ground the field post with the engine running if it then shows charge the reg is bad if that dont show charge the gen is bad might just need cleaning and new brushes do you want to keep it original or modify do you have a magneto or a dist?
Post A Followup
: Re: Re: Gas tank solution
