Re: super c throttle
Posted by JONATHAN MIRGON on September 29, 2002 at 15:41:23 from (206.183.252.114):
In Reply to: super c throttle posted by bob on September 29, 2002 at 12:01:40:
YOU MAY FIRST TRY TAKING THE LINKAGE OFF AT THE CARB AND BE SURE THAT THE LINKAGE DIRECTLY ON THE CARB IS OK. IF THAT IS OK YOUR PROBLEM IS PROBABLY INSIDE THE GOVERNER ITSELF, MAYBE A BROKEN SPRING, OR THE SMALL BEARING ON THE END OF THE SHAFT. IF YOU NEED PARTS I HAVE SOME EXTRA GOVERNER PARTS LAYING AROUND.
Post A Followup
: Re: Re: super c throttle
