Farmall A Engine Repair
Posted by Mike(NY) on September 29, 2002 at 18:33:57 from (66.218.5.3):
I have a 1944 Farmall A. When I first got it a couple of years ago I noticed that there was radiator fluid blowing out of the oil intake. This past winter when I started it up, I noticed radiator fluid leaking out between the engine block and the head in a steady stream. I was advised by a friend who works on engines that a faulty head gasket was to blame. I would like to know if anyone knows of any good resource book that goes through rebuilding this engine. I was advised that while I have the engine apart to replace the head gasket, that I might as well check and replace other parts as needed. I have not done any work this major before on an engine and just want to make sure I do it right. Thanks to all of you good people out there in advance.
Mike(NY)
Post A Followup
: Re: Farmall A Engine Repair
