Re: Leaking Hydraulic Unit
Posted by Paul Shuler on September 29, 2002 at 19:31:12 from (66.119.2.82):
In Reply to: Leaking Hydraulic Unit posted by Dan England on September 29, 2002 at 19:15:31:
If it is leaking into the crank case, fear not. It is not a big job.The touch control unit can stay in it's place. It is the pump up by your dist or mag that need to be taken off and new seals put in. Shouldn't take more than a hour unless you run into some unforseen problem. If it is the touch control unit under the gas tank, I've not been into that so can't help you there.
Post A Followup
: Re: Re: Leaking Hydraulic Unit
