Not a bad idea, but I think the 504 has an internal cylinder for the 3pt/fast hitch. No limiting collar.
That gives me an idea for something else to look at, though.
The upper lift arms are the same for 3pt and fast hitch if I'm not mistaken. The difference is in the position that they're mounted. I think they're on a splined shaft and can be "clocked" to different positions for 3pt or fast hitch operation. Someone may have clocked the lift arms higher to get the fast hitch to lift higher. By doing this they limited how far down the fast hitch will go.
A fast hitch should drop almost to the ground at least that's how it was on the old 560. With the drawbar and extension plate installed, the tip of the plate would just about touch the ground with the hitch all the way down.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
