Re: Re: Old Raceway M-Main Bearing Report
Posted by jal-SD on October 01, 2002 at 06:30:19 from (64.68.166.199):
In Reply to: Re: Old Raceway M-Main Bearing Report posted by randy hall on September 30, 2002 at 16:18:07:
Red, how do you plan to use your M? After years of working H that had NO oil pressure when at idle, we finally took the engine apart & put in new cam bushings. Whalla-oil pressure @ idle. I'd THINK your M might have the same issue. Looks like you've got good pressure when the RPM's are up, so unless you're going to work it @ idle for long periods of time, I'd fix up the pump & put her back together. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Re: Old Raceway M-Main Bearing Report
