Re: Plug Heat Range
Posted by Gene on October 01, 2002 at 07:47:29 from (65.56.62.229):
In Reply to: Plug Heat Range posted by sammy the RED on September 30, 2002 at 20:54:00:
Sammy: For a half second I thought you typed the whole note.(just jokin) Very good info sammy. Thanks for the copy and paste. I also saved it. G.
Post A Followup
: Re: Re: Plug Heat Range
