Re: What is the best way to store my 350D fuel
Posted by Bob M on October 01, 2002 at 08:37:11 from (165.170.128.68):
In Reply to: What is the best way to store my 350D fuel posted by Doug 350D on October 01, 2002 at 07:50:32:
Doug - I'm also in upstate NY. Here's how I do it: Get a bottle of diesel fuel conditioner (Technol, Penray, Fleetguard, etc.) Add enough to the tank to treat a tankful, then fill the tank with FRESH diesel to mix it up. Now run the motor a few minutes to distribute the treated fuel throughout the system. Drain the water trap after you shut it down - you should be set for the winter.
Think snow!!
Post A Followup
: Re: Re: What is the best way to store my 350D fuel
