Re: Super H Update
Posted by The Red on October 01, 2002 at 09:22:55 from (206.246.187.2):
In Reply to: Super H Update posted by MNBill on October 01, 2002 at 08:23:38:
Sounds like timing to me.
Get #1 piston on TDC compression stroke.
Loosen distributor clamp bolts.
Turn on ignition.
Turn distributor until you see the points spark, i.e. just opening.
Turn off ignition.
Tighten clamps.
Wherever that rotor is pointing, the corresponding post on the distributor cap wires to #1 spark plug.
Wire 3,4,2 in a clockwise order on the cap.
Install rotor and cap and give her a try!
Post A Followup
: Re: Re: Super H Update
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
